I have a rci 2995 board#ept695011a that was working fine then all of a sudden it quit.The only thing that works now is the lights on the meters every thing else has quit no frequency counter no transmit or receive hoping Rick or someone else may be able to help. Thanks in advance for any replies.
sounds like you lost a power supply . were you running a fan kit from rci? If not that is probably the problem . This is the number one issue with the piggy back large radios . got to keep them cool
Thanks for the quick replies. Rick i was hoping you would help cause i know if anyone could help find the problem it would be you i will check the voltages at q50 and q51 and let you know what they are. I will also unhook power to power amp and see what happens. Thanks for the help.
