RCI 2990 No TX output
sb340
First Name: Wayne
Post by sb340 »
Radio Make and Model: RCI 2990
Test gear available: HP 8924c Service monitor
Symptoms: NO TX output.Does not have any Voltage on the pre driver 2sc2314
What is working: RX works Fine
What has been tried: Checked the Trans for shorts
Did it suddenly happen ?: Yes
sb340
First Name: Wayne
Re: RCI 2990 No TX output
Post by sb340 »
I have Found that i have 8 volts on the emitter of Q38 on RX but only about 1.6 volts on the Base. with the Transistor removed.Anybody have any ideas??
Thanks
