Ham Intl. tuning prob
Radio Make and Model: Ham International Concorde II
PCB Number: PTBM121
Test gear available: Freq counter
Symptoms: Mid band cannot be tuned correctly, CT2 will go 20.327-20.328 MHz
What is working: Lo and Hi band can be tuned normally
What has been tried: Changed Mid band crystal to Lo band slot and did the same thing there
Did it suddenly happen ?: Worked fine 2 months ago, has been powered off and now it doesn't
PCB Number: PTBM121
Re: Ham Intl. tuning prob
It sounds like the Mid band crystal has had it's day and needs replacing, what frequency is on it as I might have one.
20.330 MHz, grrreat if you have one
I'll be happy with one! You will receive pm shortly.
What type is it, is it plug in or soldered in.
Plug in. There are slots for xtals in the board.
I've posted you one of each, with a bit of luck that should sort your problem out.
Thanks!!
Your welcome and if you ever need a S.Hi crystal I've got loads of them.
