Radio Make and Model: Galaxy 44
Test gear available: Volt+Ohm Meter Watt+Modulation Meter
Symptoms: Varible Doesnt Work + No Modulation
What is working: EveryThing But Varible +Modulation
What has been tried: Nothing ,
Did it suddenly happen ?: Yes
Anything else that may be of help?: Everything Worked Perfect Until I Hit A Big Pot-Hole In The Road.Now No Varible With A High Dead Key +No Modulation. Maybe A Bad Solder Joint Thanks To The Pot-Hole.Any Help Would Be Great And Needed
