In need of Schematic for SuperStar 3600
Posted: Tuesday 14th Feb 2012, 12:23
by Pepe Le Pew
Radio Make and Model: Superstar 3600
PCB Number: SRT3600-10
PLL Number: MC145106
Test gear available:
Symptoms:
What is working:
What has been tried:
Did it suddenly happen ?:
Anything else that may be of help?: I want to do the receive modification using the 2sc2999, and the 1n6263 Shottky Barrier diodes. Need to know which diodes, and which transistor need to be changed.
Re: In need of Schematic for SuperStar 3600
Posted: Tuesday 14th Feb 2012, 17:55
by sonoma
Remove and replace TR17, D1, D2, D23,D24 . found these in my notes .take a look at the board and see if this is the ones. should be.
Posted: Wednesday 15th Feb 2012, 10:30
by Pepe Le Pew
Thanks for your help. Just finished the mod. Turns out it is TR17, D1, D2, D10, D11... And it's one of the best mods that you can do for your radio, IMOP
Posted: Wednesday 15th Feb 2012, 13:06
by sonoma
great that you got what you needed at least I was half right. the 3600 10 board is what puzzled me. unusual board .not seen much.
