Palomar 450HD
Posted: Monday 11th Jun 2007, 4:39
hello, I have a 450HD a few months old, having some problems... i noticed for awhile the modutation led under the power level switch (center switch) was no longer lighting when transmitting. now the relay has a problem. Too see if my output transistors were ok I made a small hole in the relay cover, pushed it closed manually and keye'd my driver. amp showed 200 watts dead key. for some reason the relays not energizing. if i power amp on and off while keye'd up it transmitts for a split second. seems the rf just doesnt hold the relay closed. this amp appears to be contructed in a way thats not easy to get at the circuit board short of lifting the finals. Maybe I'm missing something there. Any advice on all this will be much appreciated! thanks, skywalker, central cali coast
